    Basic vray sketchup tutorial: Change the Output Render
    renderpluginsextensions
    2 Posts 1 Posters 6.5k Views 1 Watching
    • sunary0S
      sunary0
      Setting the output size of the rendering image is one of the things we must consider before starting the rendering process in vray sketchup.
      By default the image size or resolution set by Vray is 800 x 600 pixels with a color density of 96 dpi and a bit depth of 24. If you feel that the size is not satisfactory, you can change it this way
      1. First open your sketchup
      2. Open the Vray options editor.
      https://d2t1xqejof9utc.cloudfront.net/pictures/files/184697/original.JPG?1589038400
      1. Open the Output tab and select the size according to your preference.
      https://d2t1xqejof9utc.cloudfront.net/pictures/files/184698/original.JPG?1589038430
      finished and hopefully useful.
      • sunary0S
        sunary0
        how to restore the lost sketchup file because I forgot to save it?
