Back and forth motion in single click
Hi. I'm new to dynamic components.
I'm trying to model a cam motion, with a follower rod that would rise and and fall back down with a single click. For the life of me, I can't figure out how to do such a thing.
The only alternative I've been able to come up with is to have the cam do a half-rotation of 180 degrees per click so that it tracks the position of the follower rod. It's not the ideal solution.
Can anyone help? Thank you!
see
formula used:
did not see your post until today, after a bit of research on cams, (not my field, I'm carpenter and estimator)
need only the rotation and the formula does the rest
Register LoginAdvertisement
