    Back and forth motion in single click
    Scheduled Pinned Locked Moved Dynamic Components
    2 Posts 2 Posters 6.0k Views 2 Watching
      1_more_Robot
      Hi. I'm new to dynamic components.
      I'm trying to model a cam motion, with a follower rod that would rise and and fall back down with a single click. For the life of me, I can't figure out how to do such a thing.
      The only alternative I've been able to come up with is to have the cam do a half-rotation of 180 degrees per click so that it tracks the position of the follower rod. It's not the ideal solution.
      Can anyone help? Thank you!
      automaton demo.skp
      • P
        pcmoor
        see
        https://www.academia.utp.ac.pa/sites/default/files/docente/72/material_de_apoyo_para_asignacion_4_ecuacion_de_lazo_cerrado_para_una_leva_de_perfil_circular.pdf
        formula used:
        did not see your post until today, after a bit of research on cams, (not my field, I'm carpenter and estimator)
        need only the rotation and the formula does the rest
        automaton demo.skp
