    Fredo6 plugins - LEGACY versions prior SU2017
    27 Posts 15 Posters 35.1k Views 15 Watching
      Make sure you also have the latest versions of LibFredo6 and the Sketchucation Extension Store tool installed. Then quit and restart SketchUp.
      • P Offline
        PropertyToday
        reinstaling the Lib helped , thanks
          brianhausfeld2 Newcomers
          Hi, is there any way to get curviloft to work with Sketchup 2015 on a Mac. I lost my old computer, but some version of it used to work on there. Is there any other way to loft with Sketchup 2015? Thank you for your help and quality products.
            There is no older version of Curviloft. It requires SketchUp 2017 or newer. There are other lofting plugins/extensions available that might work for. You might look at TIG's Extrude Tools to start.
              Thank you! That kind of worked. I need to loft a mesh along a curving loop. TIG worked as a line, but I would like to loft the mesh. Is there any other lofting tools. Simple loft did not work at all. Thank you so much for your help.
              Halfpipe Spine Loop.skp
                monographix Newcomers
                Hello.
                The Legacy Round Corner file is not the <2017 but a <2016 (=<2015) as its not working with my 2016 and presents me the message that this is a legacy Roundcorner suitable only for versions prior to 2016
                Can we have the downloadable file replaced by the actual file compatible up to 2016?
                Thank you
                  billy001
                  This post is deleted!
                  • 2 / 2
