    Diffuse layer to place texture.
    renderpluginsextensions
    1 Posts 1 Posters 4.4k Views 1 Watching
    • R
      rspierenburg
      Good morning,
      I'm trying to create a Corrugated metal texture in VraySU and I have all the maps setup properly, but for the main diffuse layer I want a simple color map so I can change the color of the material as needed. The issue I'm having is that I need to be able to see the corrugated texture in SU in order to place it correctly. I tried creating a second Diffuse map using the height bitmap on top of the colored one and turning it off in VRAY but it doesn't seem to link itself to the height/bump maps so moving and scaling the texture in SU doesn't translate when rendering.
      Any thoughts on how this can be done?
      I know in earlier versions of VRAY this worked by making the top diffuse layer 100% transparent, but I can't seem to get that to work now.
      Robert
