    Transition from lozenge to circle along arc
    3 Posts 2 Posters 994 Views 2 Watching
    • C
      cthawkinson
      Good evening all,
      This is my first post here, even though I have used this forum often to answer questions that have come up as I have use Sketchup. I have run into an issue which I haven't been able to solve on my own, so hopefully someone here can help.
      I am trying to connect a hollow cylinder which is lozenge shaped to a hollow cone which is circular. This connecting piece will transition from the lozenge to the cone via an arc.
      Here is what I have done so far:
      1. I made a circle matching the diameter of my cone and hollowed it out.
      2. I made another circle matching the diameter of the lozenge and hollowed it out.
      3. I drew an arc connecting the inside and outside of my two circles.
      4. I used the Follow Me tool to draw the arced cylinder.
      That all worked great, as I had my cylinder. You can see this in the attached SU Make 2017 lozenge to circle along arc.png. I made the green cylinder as described above, which connects to the gray cone on the right and the purple/yellow lozenge on the left.
      Now I have my cylinder, wanted to transform the wider end into a lozenge using some tips I found at in this forum topic:
      https://sketchucation.com/forums/viewtopic.php?f=79&t=43234
      In spite of the good instructions in this topic, I am not getting the desired results. Instead of transition the cylinder along its entire length, it will only do so in the first segment, or I end up with lozenges at both ends instead of just one.
      Do any of you have any thoughts as to what I am missing? I have also uploaded a Sketchup Make 2017 file of the model (SU Make 2017 lozenge to circle along arc.skp) if anyone wants to take a look at that. If you do, please note that I separated each piece by 5mm eliminate z-fighting.
      Thanks in advance for taking a look at this.
      Chris
      Sketchup model image
      Sketchup Make 2017 model
        a brute method πŸ˜„ Thx Fredo6 and its versatile Curviloft 😎
        Kill surfaces and segments for keep only circular curves
        you can make the same with other if you want truncated conic volumes
        https://i.postimg.cc/rpYZyFLG/like-thatt.jpg
        Funny i have made a conic form few days ago for the free Simlab Composer Lite πŸ˜„ (max 1920 *1080)
        (geometric caterpilar curves + spheres )
        https://i.postimg.cc/gjZFpM2m/carterpilar.jpg
        • C
          cthawkinson
          Thanks! I used the Skinning tool and that did exactly what I wanted; creating a surface along the arcs I created to get a smooth transition from the lozenge to the circle.
          Thanks so much for helping out. I am not back on track!
