    Can't get shortcut to work
    2 Posts 2 Posters 783 Views 2 Watching
    • pbacotP
      Setting up new computer. I am trying the same shortcut I had for Component edit/ hide rest of model toggle. It looks OK--same as I have always used. I am using option-H. But it doesn't work. Seeing if the system has a similar command, but don't see it.
      what can cause shortcuts not to work. This is a PITA to try to work without that one!
        As a test, can you get it to work with a different keyboard shortcut?
