    Purge Material in Component
    3 Posts 2 Posters 1.7k Views 2 Watching
    • P
      Picky
      Hello,
      a bit confusing: Is it possible that you cannot purge materials on non-grouped objects after deleting them?
      Example: I erased a material in the component at startup, for example Chris hair. After that when I try to purge the material hair in editor, I get "the material is in use". When I delete the whole component it works fine.
      The background: In my object I've got a whole of a lot of strange materials, amongst others Chris shoes, which is defenitivly not in use. Trying to delete it I get the same message. Well, I did it manually.
      Is there a plugin to show which objects are used by the materials? Or even better, is there any material cleaner who is able to do this? Purgeall, cleanup don't help, even SU-statistics!
      Thanks a lot in advance!
      Picky
      • BoxB
        You can't purge a material before you purge the component it was in.
        • P
          Picky
          Thanks a lot, Box!
          Yes you can! But...
          I created 4 simple objects, added different colours and created a comoponent.
          I deleted one or several objects, and I was able to purge two materials. But always the one I added last its material will not be purged. This has to be removed manually.
          The problem is we have a hell of lot of components in our projects which are mostly downloaded from the warehouse (we are restaurantdesigners). This means a lot of mess, most of the materials are not labeled or purged before. It would help to know which objects are (were) assigned to the material. A plugin would help!
          Regards Picky
