    New old problem
    1 Posts 1 Posters 699 Views 1 Watching
    • pmolsonP
      pmolson
      windows 10, sketchup 2020
      I have been using 2020 since it came out with no issues.
      Today I went to modify a dynamic component (have been using the some dynamic component for ever)
      & I received these messages when the DC plug in launched.
      I had this problem back in 2016 and the final answer then was SU team saying it was a known problem and would be dealt with. In time it was.
      This is the link to that thread back in 2016
      https://sketchucation.com/forums/viewtopic.php?f=15&t=63876
      Strangely enough, I am able to work with the dc if I use edit in place.
      Also should note that this seems to related only to one drawing file. I did copy and paste the model into a new drawing file and it seemed to be ok as I was able to work with the Dc until I saved the file. It then started giving the errors again.
      Because this is only effecting one model (for now) I am ok with using the edit in place work around, but thought I would put this out there in case there is a known fix for this issue.
      Thanks.
      Paul
