    Displays
    1 Posts 1 Posters 644 Views 1 Watching
    • R
      Rinte
      Hello all
      I have just purchased a new MacBook Pro 15” fully loaded !..to replace my old one which I used to use with apples 30” Cinema Display ! Unfortunately the new MacBook Pro only has thunderbolt and no mini display connector so at the moment I cannot connect to the Cinema Display I can purchase a stone henge hub which will get the Cinema Display working again as it has a mini display connector to work with the new MacBook all this will cost around £200.00 !.. or do I bite the bullet and purchase something like a benq PD3220U 4K display to replace the apple Cinema Display which runs at 2560 x 1600 obvously a lot lower res than current 4K displays but a good resolution all the same and a great display …what would you do ? and current thoughts on using 4K displays and sketch up most appreciated? Benq also make a 27” Thunderbolt Display maybe a better choice than 31.5 ? Anyway any users advice most appreciated…thanks James
