    Problem exporting SU -->autoCAD
    8 Posts 2 Posters 1.8k Views 2 Watching
    • P
      pace514
      Hi all !!!
      Trying to export in .DWG i have this error message. Then,using DWG true view, it takes forever to open and i can barely do whatever. I suppose i got much more polys than i should but why that same drawing is pretty responsive in SU ?
      Should not is be as fast in cad viewer ?
      https://www.dropbox.com/sh/wg5quydr1av5jyo/AAAL2vZlSbc0QYpPclo9kUVNa?dl=0
      Thanks for your help !
      Have a nice evening !
      Pace from Montréal
      • G
        Glenn at home
        Ok, I gave it a shot and here is what I found out. Your original file with all of those scenes was not working well. I was able to import the dwg into AutoCAD 2020 but it was a hog and slow to use. I deleted all of the scenes and saved to a 2018 SU file and used AutoDesk's free SU import utility and it's smooth as silk now. The dwg files grows from a 45 mg skp to a 86.5 mb dwg. Not sure on what your end result is on this.
        • P
          pace514
          So, from what i understand, i would have to have autoCAD in order to download that plugin. I only have
          autodesk DWG TrueView wich is free. Is there an other way to do ? Or would you be kind enough to send me your result ?
          Thanks for your time anyway Glen at Home !
          Appreciate
          Pace
          • P
            pace514
            Hummm... When i click on the link, my Dropbox opens and a little red window is telling me that the file does not exist ???
            • G
              Glenn at home
              Sorry, I must have done something wrong on my end. Let me try again.
              Edit: Try the above link again. Sorry
              • G
                Glenn at home
                Sorry for delay, I was out for a bit. Try this....
                https://www.dropbox.com/s/xeih0jq22vdqdrl/3D%20Rona.dwg?dl=0
                • P
                  pace514
                  Awesome !!!
                  Work very well !
                  Thank you so much Glenn at home !
                  You made my day !
                  Cheers !
                  Pascal
                  • G
                    Glenn at home
                    Thanks, glad to help 😄
