Problem exporting SU -->autoCAD
8 Posts 2 Posters 1.4k Views 2 Watching
    pace514
    Hi all !!!
    Trying to export in .DWG i have this error message. Then,using DWG true view, it takes forever to open and i can barely do whatever. I suppose i got much more polys than i should but why that same drawing is pretty responsive in SU ?
    Should not is be as fast in cad viewer ?
    Dropbox
    (www.dropbox.com)
    Thanks for your help !
    Have a nice evening !
    Pace from Montréal
      Glenn at home
      Ok, I gave it a shot and here is what I found out. Your original file with all of those scenes was not working well. I was able to import the dwg into AutoCAD 2020 but it was a hog and slow to use. I deleted all of the scenes and saved to a 2018 SU file and used AutoDesk's free SU import utility and it's smooth as silk now. The dwg files grows from a 45 mg skp to a 86.5 mb dwg. Not sure on what your end result is on this.
      SketchUp Pro 2024/2025 Dell XPS 8950 i9-12900K 64GB Ram RTX 3080
        pace514
        So, from what i understand, i would have to have autoCAD in order to download that plugin. I only have
        autodesk DWG TrueView wich is free. Is there an other way to do ? Or would you be kind enough to send me your result ?
        Thanks for your time anyway Glen at Home !
        Appreciate
        Pace
          pace514
          Hummm... When i click on the link, my Dropbox opens and a little red window is telling me that the file does not exist ???
            Glenn at home
            Sorry, I must have done something wrong on my end. Let me try again.
            Edit: Try the above link again. Sorry
              Glenn at home
              Sorry for delay, I was out for a bit. Try this....
              https://www.dropbox.com/s/xeih0jq22vdqdrl/3D%20Rona.dwg?dl=0
                pace514
                Awesome !!!
                Work very well !
                Thank you so much Glenn at home !
                You made my day !
                Cheers !
                Pascal
                  Glenn at home
                  Thanks, glad to help 😄
