    🫛 Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    443 Posts 107 Posters 446.6k Views 107 Watching
      Danish9762
      Hi sir im using sketchup 2017 when i install this plugins by extension manager so im getting unsigned plugin please contact plugins developer. Not working please gix it or tell me how to fix it
      • jujuJ Offline
        juju
        @Danish9762: You need to relax the extension loading policy you have set withing SketchUp.
        • samuel_tS Offline
          samuel_t
          @Danish9762 "Unsigned" problem isn't a bug, it just means plugin doesn't come from SketchUp Extension Warehouse.
          As suggested by @juju, relax SketchUp extension loading policy settings. To access these settings, select Window > Preferences > Extensions Policy (Microsoft Windows) or SketchUp > Preferences > Extensions > Policy tab (OS X). SketchUp has three available extension policy modes: “Identified Extensions Only”, “Approve Unidentified Extensions”, and “Unrestricted”. Select “Unrestricted” then restart SketchUp.
          • sketch3d.deS Offline
            sketch3d.de
            based on the MeshLab engine should maybe be mentioned.
            • P Offline
              paladinjnr
              Will do
              Hi Here is a link to the model as requested.
              Filehorst wurde abgeschaltet! Filehorst has been shut down!
              (filehorst.de)
              Many Thanks Rae
              Thank You for your help, I have spent most of today importing different models , some worked some didn't , so I am gong to give it a break for a couple of weeks then pick it up again .
              Once again many thanks for your help
              Keep up the good work
              Rae
              • samuel_tS Offline
                samuel_t
                It was already mentioned on GitHub page. And now, it's also mentioned on SketchUcation page.
                  • OxerO Offline
                    Oxer
                    Thanks for the macos version!! 👍
                    SU2017 & macOS 10.13.6
                    I found some problems with the importing:
                    1. If you import a file that contains a space in filename (e.g. Pinas Prueba.obj), it appears a popup message window in Sketchup: "Import Error". I looked in the Console (I opened SketchUp via Terminal) and this is the error message:
                    assimp export; wrote output file; /Users/Oxer/.UniversalImporter/tmp/Pinas Prueba.obj.dae
                    Warning; uri contains white space, dom will convert them to %20 in output files!
                      uri=#Pinas Prueba.obj.obj
                    Error; daeStandardURIResolver;;resolveElement() - failed to resolve file;//localhost/Users/Oxer/.UniversalImporter/tmp/Pinas Prueba.obj.dae#Pinas Prueba.obj.obj
                    2. With a file without spaces in filename Universal Importer work fine but nothing is imported, it appears a popup window in Sketchup with this text --> 'An empty component cannot be inserted'
                    I probed with different file format: obj, dae, fbx, blend and the same in all.
                    Perhaps it is a SketchUp error or perhaps is a problem with the scale, I don't know it, but I tried changing the 405 line in converter.rb:
                    dae_export.sub!('meter="1"', 'meter="0.01"')
                     to
                     dae_export.sub!('meter="1"', 'meter="1"')
                    And the Universal Importer inserted a flat component with two lines, see the image:
                    3. When you select a file (e.g. in the Finder) to import, the plugin copy all Finder files to the temp folder, why? and are this files delete automatically or is it necessary delete manually?
                    4. A minor detail, the texts 'Select a 3D Model' '3D Models |.3d;.3ds;.3mf;.ac;.ac3d;.acc;...' 'Select a Texture Atlas (Optional)' 'Images |.jpg;.png;*.bmp;||' do not appear in the importing windows.
                    Again, thanks for your efforts !!
                    [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
                    • samuel_tS Offline
                      samuel_t
                      Thanks for detailed report! 😉
                      @oxer said:
                      1. If you import a file that contains a space in filename (e.g. Pinas Prueba.obj), it appears a popup message window in Sketchup: "Import Error". [...]
                      OK. I'm gonna fix that.
                      @oxer said:
                      2. With a file without spaces in filename Universal Importer work fine but nothing is imported, it appears a popup window in Sketchup with this text --> 'An empty component cannot be inserted' [...]
                      Did you tried to import a completely different model? Could you please upload original "Pinas Prueba.obj + mtl + jpg" to a file hoster or here. This way I could debug it.
                      Model and associated files are copied to a temp folder to avoid invalid characters in path.
                      These temp files are automatically deleted at each import.
                      Strange. Maybe it's a SketchUp API bug on MacOS... 😕
                      • OxerO Offline
                        Oxer
                        Hi, I tried to import the same Pinas.obj file with QuadTools plugin and the importing works fine.
                        Here the files:
                        Pinas.obj, Pinas.mtl and texture
                        • OxerO Offline
                          Oxer
                          It would be interest if other mac users test the file with other macos & SketchUp versions.
                          • samuel_tS Offline
                            samuel_t
                            @oxer said:
                            EDIT: I see that you have change the converter.rb to V2, I'll test this new version of the file.
                            Super. Thanks for your help.
                            • OxerO Offline
                              Oxer
                              I overwrited the converter.rb file and this is the result importing Pines.obj file:
                              Two lines crossed in a vertical plane
                              I made some testing with another models and formats, I used Blender to export the models to different formats.
                              Original models created with Blender 2.82.
                              THE RESULTS
                              1. FBX format
                              The importer works but there are some issues:
                              A) The scale is multiplied by 100.
                              B) It doesn't import the UVMap.
                              C) With complex models the edges are displaced a little (see the image).
                              2. OTHER FORMATS
                              A) Cube 1 x 1 m, OBJ, PLY and DXF formats.
                              B) Sphere 1 x 1 m, OBJ, PLY and DXF formats.
                              EDIT: I see that you have changed the converter.rb to V2, I'll test this new version of the file.
                              • OxerO Offline
                                Oxer
                                Thanks to you for your work!! 👍
                                converter.rb V2 tested and it works fine now, fantastic!! 🎉
                                Some issues only, the Z axis is flipped and the scale isn't correct, for the moment I probed with FBX format only.
                                • OxerO Offline
                                  Oxer
                                  OBJ FORMAT
                                  The same issues as FBX format, scale (in this case is more small) an Z axis.
                                  PLY FORMAT
                                  The same issue with scale as OBJ format but the Z axis is correct. 👍
                                  DXF FORMAT
                                  The same issue with scale and axis as OBJ format , I think dxf doesn't support textures.
                                  • samuel_tS Offline
                                    samuel_t
                                    Here the files:
                                    Hello Oxer,
                                    I can import "Pinas.obj" on Windows. So it's maybe related to macOS or SU.
                                    Could you please overwrite your installed "converter.rb" with attached one?
                                    converter.rb
                                    Then restart SketchUp. Then try to re-import "Pinas.obj". Thanks for help. 😉
                                    • samuel_tS Offline
                                      samuel_t
                                      @Mac Users
                                      I've fixed again plugin code. I hope this one works on macOS! 😛
                                      Please overwrite your installed "converter.rb" with attached one.
                                      converter.rb
                                      Then restart SketchUp. Then import a model. Tell me if it works.
                                      Thank you. 😉
                                      • samuel_tS Offline
                                        samuel_t
                                        1.0.3 version fixes critical bugs on macOS and Windows. macOS is now fully supported.
                                        Download latest Universal Importer plugin from SketchUcation PluginStore.
                                        • samuel_tS Offline
                                          samuel_t
                                          @oxer said:
                                          Fantastic plugin but I work on mac, is there plan for macos support?
                                          Problem is I don't have macOS computer. Maybe I could try code it on a virtual machine?
                                          Since v1.0.3, plugin is compatible with macOS.
                                          @oxer said:
                                          Spanish Language File
                                          Thanks for Spanish translation.
                                          • samuel_tS Offline
                                            samuel_t
                                            1.0.2 version adds:
                                            • Preliminary macOS support,
                                            • Spanish translation.
                                            • 22
                                            • 23
                                            • 2 / 23
