    Select Horizontal Hidden lines?
    4 Posts 2 Posters 1.5k Views 2 Watching
    • F
      ffrancis
      Hi guys,
      Please see attached JPG. I wanted to select the horizontal hidden lines only without selecting the diagonal. Is there a quick tip / plugin or anyway to do that rather than selecting them one by one? hope someone can help me with that. Thanks.
        Unfortunately your screen shot really doesn't show us what you are wanting to do. Have you tried turning on Hidden Geometry so you can see those edges? What is you want to do after selecting these edges?
        By the way, are you still using SketchUp 2015 Make as your profile indicates?
        • F
          ffrancis
          I apologize for the misunderstanding. here is another screenshot showing the hidden horizontal lines that I want to select without the diagonal lines in order to add horizontal mullions. Thanks
            You might try Select Loop which is part of Thom Thom's Quad Face Tools. I would run CleanUp3 first to make sure you get rid of any unneeded edges there might be.
            Thanks for starting to update your profile. I assume you mean you are using SketchUp 2019 Pro.
