    Medeek Floor
    151 Posts 6 Posters 23.5k Views 5 Watching
    • medeekM Offline
      medeek
      After watching Tony's video I realized we probably need a couple additional advanced options for floors/decks with deck boards enabled. The two that immediately jump out at me are:
      1.) Trim Band or Picture Frame
      2.) Deck Wrap
      Both of these can easily be achieved since they are very similar to my existing rim board code.
      In fact, I can even enable a remove option for each of these modules similar to the rim board module. The parameters shall be:
      1.) Trim Band: Yes/No
      2.) Trim Width
      Trim Thickness: Typically one would set this to the same thickness as the deck boards but I better provide this just in case.
      3.) Trim Overhang
      4.) Trim Corners: Lap, Reverse Lap, Miter
      5.) Trim Material
      6.) Remove Trim: Empty by Default
      1.) Deck Wrap: Yes, No
      2.) Wrap Depth
      3.) Wrap Thickness
      4.) Wrap Corners: Lap, Reverse Lap, Miter
      5.) Wrap Material
      6.) Remove Wrap: Empty by Default
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 0.9.9g - 10.19.2024
        • Enabled wrap for decks.
        • Enabled a trim band (picture frame) for decks.
        Note that these two feature can only be used when the deck board option is turned on.
        design.medeek.com
        • medeekM Offline
          medeek
          Tutorial 12 - Trim and Wrap (6:42 min.)
          design.medeek.com
          • medeekM Offline
            medeek
            Version 0.9.9h - 10.21.2024
            • Enabled custom overhangs for decks.
            • Enabled double trim band for decks.
            • Fixed a number of minor bugs related to custom (removal) trim bands and overhangs.
            design.medeek.com
            • medeekM Offline
              medeek
              Tutorial 13 - Custom Deck Board Overhang (9:09 min.)
              design.medeek.com
              • medeekM Offline
                medeek
                Version 0.9.9i - 10.22.2024
                • Added the following layers/tags to the global settings and deck module.
                Two different floor assemblies adjacent and forming one deck. Where they contact I've removed the overhangs, wrap and trim (on one assembly) using the new features recently added. Maybe there is enough functionality now to actually create some real decks.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 0.9.9j - 10.25.2024
                  • Added a vertical offset parameter for deck fascia/wrap.
                  • Added an air gap parameter for deck fascia/wrap.
                  • Changed the deck "wrap" to deck "fascia in the menus.
                  • Enabled deck/floor fascia independent of floor sheathing or deck boards.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 0.9.9k - 10.30.2024
                    • Added floor coverings with an underlayment option.
                    • Added the floor coverings toolbar with the following five items: Draw, Move, Edit, Regen and Delete.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 0.9.9l - 10.31.2024
                      • Fixed a bug with the floor covering tools (floor covering selection): Move, Edit, Regen and Delete.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 0.9.9m - 10.31.2024
                        • Added a "Wall" draw mode to the floor covering draw tool.
                        • Enabled "Perimeter Options" within the edit menu of the floor covering tool.
                        When drawing floor coverings you can now toggle between polyline, face or wall mode. Wall mode will allow you to select any number of Medeek walls (in logical order) which will define the boundary or perimeter of the floor covering. At first I was going to make this a fire-and-forget type of draw mode but instead it makes sense to retain the association even after the initial floor covering is created.
                        If any of the walls are deleted or somehow the "link" is broken the floor covering assembly will resort back to its "point" mode and the save points generated by the walls. So it will or should fail gracefully in these cases. Also note that there is a wall side associated with each wall assembly, this can easily be changed from EXT to INT or vice versa as needed.
                        I will make a new tutorial video showing this increased functionality and it should further help explain how this new system works and how to use it. I've been testing this feature for almost five days now so I think it is fairly robust but I am sure there may be specific cases that may defeat my algorithms. Bottom line, this is brand new so proceed with some caution.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Tutorial 15 - Floor Coverings with Walls (11:47 min.)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 0.9.9n - 11.06.2024
                            • Enabled "Openings Options" within the edit menu of the floor covering tool.
                            Tutorial 16 - Floor Coverings with Openings in Walls (7:59 min.)
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 0.9.9o - 11.07.2024
                              • Added a Material X-Offset parameter for the floor covering material.
                              • Added a Material Y-Offset parameter for the floor covering material.
                              • Added a Material Rotation parameter for the floor covering material.
                              I will probably add in the same offsets and rotation parameters for the underlayment as well, but I will hold off for now until it is requested. I really want to get back onto the floor opening tool.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 0.9.9p - 11.08.2024
                                • Added a "Wall" draw mode to the floor draw tool.
                                • Enabled "Perimeter Options" within the edit menu of the floor tool.
                                Tutorial 17 - Linking Floors and Walls (11:09 min.)
                                I apologize I got so interested and focused on the wall draw mode for floors that I completely forgot about the updates I made to allow for drawing floor coverings on slab etc... I will drop those updates into the very next release which will probably be this weekend.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  As requested here is the edit menu with an offset parameter added to the Perimeter Options:
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 0.9.9q - 11.10.2024
                                    • Added a perimeter offset parameter within the edit menu for floors drawn in "Wall" mode.
                                    • Added two "Wall Mode Options" to the Floors tab of the global settings: Perimeter Offset and Move Walls.
                                    • Connected the "Move Floor Edge" tool to the Medeek Wall API so that moving floor edges (Wall Mode Only) can also move walls.
                                    • Updated the Draw Flooring tool so that floor coverings can be applied to slabs, slab-on-grade foundations and floor trusses.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Tutorial 18 - Moving Walls with Floors (9:17 min.)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        First look at a TRIFORCE Open Joist floor:
                                        TRIFORCE® Open Joist: Peace of Mind Underfoot
                                        The TRIFORCE® open joist is a state-of-the-art product in the forefront of the construction industry.
                                        TRIFORCE® Open Joist (www.openjoisttriforce.com)
                                        There has been some call for this product line so I am working on the algorithms so that it can be configured properly. It is a bit more complicated due to the directional nature of its trimming panel (only one end can be trimmed).
                                        design.medeek.com
                                        gullfoG 1 Reply Last reply Reply Quote 1
                                        • gullfoG Offline
                                          gullfo @medeek
                                          yes! i have some custom DC to mimic this but it's flakey and i haven't revisted it, so have this "built-in" will be a nice feature.
                                          Glenn
                                          http://www.runnel.com
                                          • medeekM Offline
                                            medeek
                                            Version 0.9.9s - 11.13.2024
                                            • Added the "Open Joist" floor family.
                                            • Added the following TriForce Open Joists: OJ3-11.875, OJ4-11.875.
                                            design.medeek.com
                                            • 6
                                            • 7
                                            • 8
                                            • 5 / 8
