    Can I generate a report without a hidden object?
    4 Posts 3 Posters 1.0k Views 3 Watching
      jonasnunes00
      Can I generate a report without a hidden object or hidden layer appearing?
        Your profile says you are using SketchUp 2017 Make. Report Generator requires SketchUp Pro. If you get Pro you can generate a report showing only the selected entities in the model.
          jonasnunes00
          I have the 2019 pro now
          I have a dynamic component, which has 3 objects in it, only one appearing on the screen, but in the report 3 =/
          Tried to turn off layer, hide, always appears in report = /
          • P Offline
            pcmoor
            You could use custom attributes that do not add a value if hidden
            count visible.skp
