Location snapshot quality
Didn't Trimble say improved quality for location snapshots as a subscription only feature while the classic license would continue having the low useless quality as before?
Here at work we have machines with both classic and subscription license and when doing a test it is exactly the same low resolution on the images.
Here are the two test snapshots.
Click on the images to view them at full size.
Rather useless quality if you ask me.
What they actually said was:
Large Area Imports for Add Location. You can now easily import large sites at full resolution. How can you take advantage of this new feature? Simply zoom out a bit, then select the level from which you want to import. Be aware that importing very large areas with lots of imagery can adversely affect performance in your SketchUp model. Note that this feature is only available to SketchUp Pro and Studio subscription holders.
This is still limited to a certain image quality level which is what you pay for as part of the subscription cost. Full resolution is the not highest resolution. Higher quality imagery is available for a price and it can be had via Placemaker.
Register LoginAdvertisement
