    Dynamic multifamily unit layout
    2 Posts 1 Posters 5.8k Views 1 Watching
    • C
      coreiter
      So I'm trying to figure out the best way to do a massing study for a multifamily project. Ideally I would create a dynamic component that you draw a line and skp lays out however many30x30 units with a corridor in the middle. You would also be able to set the amount of floors. It would be cool if it could add a stair every 12 units or so, or maybe that's a user input. Obviously the units would just be a square 11' tall extrusion. I know I could start with the dynamic railing skp has by default - but is there a way to draw a line (maybe a three sided square C shape) and have it draw the units along a user defined line? Or is that more complex? I think I could make a single straight line version with the railing component, but is the user defined line version that much more difficult? Thanks!!
      • C
        coreiter
        I guess a good question is: is there a good dynamic component that kind of does this already that I can alter the components to hack and make it do what I'm asking? Again not sure about Ruby so I may be limited to the 3d warehouse. .
