    Region Render not working
    renderpluginsextensions
    1 Posts 1 Posters 5.3k Views 1 Watching
    • brodieB
      brodie
      The Region Render gets stuck either on or off using Vray NEXT. For example, if I turn it on and render a region, then turn Region Render off again and begin rendering the scene, the region render will turn back on. The only workaround I've found so far it so switch from bucket rendering to progressive.
      Has anyone else run into this issue? What's your fix?
