    Layout 2019.2 Bug Splat on Toolbar Customization
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    3 Posts 3 Posters 8.9k Views 3 Watching
    • kimi kimiK
      kimi kimi
      I'm trying to set up my toolbars like I did in LO 2018, but when I try to reopen LayOut, I get immediate bug splat. Is anyone else experiencing this? I need to delete some .plo and xml documents in AppData/...LayOut in order to come back to default and use the program again. But default setup slows me down, I need to be able to customize.
      Also, is there some quick way to migrate my workspace from 2018 to 2019, so I don't have to position every icon manually?
      • jujuJ
        juju
        Unfortunately, once you've installed all your extensions (note: not to be copied directory to directory from a previous installation) you'll have to set them up manually. Sad, I know.
          When you installed SketchUp/LayOut 2019, did you right click on the installer and choose Run as administrator? If not or you aren't sure, quit out of both SketchUp and LayOut, find the installer (Downloads folder?) right click on it and choose Run as administrator from the Context menu. Then when presented with the option, choose Repair. Make sure you have logged into Windows under your normal user, not as the system administrator.
          Unfortunately not at this time. It is a feature that has been requested, though. Perhaps in an upcoming version we'll see it.
          When I get ready to migrate to a new version (I've done it 19 times and on multiple computers) I make screen shots of the entire workspace of the previous version for both SketchUp and LayOut so I can see where all the toolbars are located. Then I import the screen shot into the new version so I can refer to it while setting up the new version.
          As Juju implied, do not copy extensions from a previous version into your new version. Install them fresh from their sources.
