    Vector rendering in perspective
    layout
    3 Posts 2 Posters 5.9k Views 2 Watching
    • S
      skylabridges
      If I have the style set to vector - is layout able to do this in perspective?
      As in, if I have 3 cubes going backwards as in the picture, could I have the first cube with a line thickness of say 2pt and the back cube have a thickness of 0.5pt, without having to do it manually?
      Thanks!
        It can be done but not in a single viewport.
        3 scenes each showing a different cube but all from the same camera position. Stacked viewports in LO with each one set to show a different line weight.
        FWIW, Depth Cue in SU can be used if you render the viewport in Raster mode.
        • S
          skylabridges
          Ok great, thank you!
