    [Plugin][$] FredoPortrait - v2.9a - 01 Apr 24
    82 Posts 23 Posters 129.9k Views 23 Watching
    • fredo6F Offline
      fredo6
      NEW RELEASE: FredoPortrait v2.2a - 19 Aug 20
      Requirement: LibFredo6 11.0a
      FredoPortrait 2.2a is for bug fixing, cosmetic adjustments and extension of validity
      Home Page of FredoPortrait for information and Download.
      Main post of this FredoPortrait thread.
      • fredo6F Offline
        fredo6
        NEW RELEASE: FredoPortrait v2.3a - 20 Nov 20
        Requirement: LibFredo6 11.3a
        FredoPortrait 2.3a is for adjustments and extension of validity
        • fredo6F Offline
          fredo6
          NEW RELEASE: FredoPortrait v2.4a - 06 Jan 21
          FredoPortrait 2.4a is for adjustments and extension of validity
          • fredo6F Offline
            fredo6
            NEW RELEASE: FredoPortrait v2.5a - 27 Jan 21
            Requirement: LibFredo6 11.6a
            FredoPortrait 2.5a becomes a paid plugin.
            There is a Free trial period of 15 days from activation, with full features. Then, you need to license the extension on Sketchucation:
            • Perpetual License: 17 €
            • Rush License (21 days from purchase date): 5 €
              See this post for instructions to license an extension on Sketchucation.
            Note: the previous version v2.4a will naturally expires on 31 Jan 21
              ltchest
              I purchased FredoStudio because i would like to copy cameras from one model to another model - but its not working.
              I think the problem is that Vray "safe frame" is enabled and that Fredo Portrait is not compatible with vray safe frame being turned on ?
              I tried turning off safeframe, and the result is much better - but the perspectives are not identical when you copy across. Is this a known problem ?
              Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
              RTX2070 + GTX1080, Driver 472.12
              • G Offline
                GeoffG
                Hello,
                I am attempting to acquire a perpetual license (3 seats) for this plugin, but can't seem to find where to input payment information to gain the license. Is there a link I'm overlooking?
                I have the plugin extension installed along with LibFredo6 and the Extension Store plugin.
                Please advise.
                • P Offline
                  patelnk4
                  @fredo6 said:
                  @rv1974 said:
                  Do you have plans to add a flatten (skp) generation from selected parts?
                  That's my plan to produce FaceMe component, but not sure this is useful as I never saw a user request for that.
                  I'm lost but I think your plugin is super cool, how do I buy it?? i tried to get the $20 perpetual license but I cant find where I put my cc info to make the purchase?? is there a link that you have or am I missing something???
                    Anne O Grady
                    Hi there,
                    In this work instruction points 2 & 3 details how to purchase the license.
                    If you have any problems just drop me a line at support@sketchucation.com and I can help you further.
                    Anne
                    SCFLicense Instructions (1).pdf
                    • fredo6F Offline
                      fredo6
                      NEW RELEASE: FredoPortrait v2.6a - 22 Apr 21
                      FredoPortrait 2.6a is for performance of contextual selection menu
                      • fredo6F Offline
                        fredo6
                        NEW RELEASE: FredoPortrait v2.7a - 31 Aug 21
                        FredoPortrait 2.7a is for extension of validity
                          amckeag
                          I understand this extension can batch export image files, such as .jpg and .png using the screenshot function. Is it possible to batch export PDFs (for vectors) as well? I have been seeking an extension to batch export PDFs either by group or selection, and this extension is the closest I've seen.
                          • fredo6F Offline
                            fredo6
                            FredoPortrait Screenshot does not export PDF, precisely because they are vector files, for which it makes no sense to take a portion of the viewport in pixels.
                            FredoPortrait Studio does the export in PDF (for model and objects). Batching these export is a good idea, but requires evolutions of FredoPortrait, which I am not sure I can do quickly.
                            • cmeedC Offline
                              cmeed
                              Hi Fredo!
                              Again your plugins enable us users to do so much more with sketchup. Thank you.
                              I have only scratched the surface regarding FPortrait using Custom Cameras.
                              Is there a Settings Page? you sometimes have one... I would like to have the window open permanently and not disappear when I click a change. Is this possible? or am I missing something?
                              Cheers
                              Chris
                              • fredo6F Offline
                                fredo6
                                Which window do you refer to?
                                  rv1974
                                  Fredo, 'generate 2d component' tool produced slightly larger 2d representation* of original one (for example 3969mm instead of 3967mm). is there possibility to make it precise?
                                  *- parallel projection of course, anycontouring mode
                                  • fredo6F Offline
                                    fredo6
                                    Would you have a model to investigate. I am not sure however that the plugin can do anything about the Sketchup inherent precision.
                                      rv1974
                                      please take a look
                                      Group_23.skp
                                        rv1974
                                        another issue: some parts in 2D component get lost
                                        Group_1.skp
                                        • cmeedC Offline
                                          cmeed
                                          Hi Fredo,
                                          I have a few problems using Portrait Studio
                                          When its open, SU looks like it jumps back a few steps. if i click into a group with Portrait open it will jump back to what ever happen a few moments ago - if I rotated , altered position or placed an object
                                          Please see you personal messages and the dropbox link to the movie i just took
                                          Cheers
                                          C
                                          • fredo6F Offline
                                            fredo6
                                            NEW RELEASE: FredoPortrait v2.8a - 25 Dec 22
                                            Requirement:
                                            • LibFredo6 13.6a
                                            • Sketchucation ExtensionStore v4.2.9
                                            FredoPortrait 2.8a is for extension of validity
                                            M 1 Reply Last reply Reply Quote 0
                                            • 4 / 5
