    [Plugin][$] FredoPortrait - v2.9a - 01 Apr 24
    86 Posts 24 Posters 135.3k Views 24 Watching
    • fredo6F Offline
      NEW RELEASE: FredoPortrait v2.7a - 31 Aug 21
      Requirement: LibFredo6 11.6a
      FredoPortrait 2.7a is for extension of validity
      Home Page of FredoPortrait for information and Download.
      Main post of this FredoPortrait thread.
        amckeag
        I understand this extension can batch export image files, such as .jpg and .png using the screenshot function. Is it possible to batch export PDFs (for vectors) as well? I have been seeking an extension to batch export PDFs either by group or selection, and this extension is the closest I've seen.
        • fredo6F Offline
          FredoPortrait Screenshot does not export PDF, precisely because they are vector files, for which it makes no sense to take a portion of the viewport in pixels.
          FredoPortrait Studio does the export in PDF (for model and objects). Batching these export is a good idea, but requires evolutions of FredoPortrait, which I am not sure I can do quickly.
          • cmeedC Offline
            cmeed
            Hi Fredo!
            Again your plugins enable us users to do so much more with sketchup. Thank you.
            I have only scratched the surface regarding FPortrait using Custom Cameras.
            Is there a Settings Page? you sometimes have one... I would like to have the window open permanently and not disappear when I click a change. Is this possible? or am I missing something?
            Cheers
            • fredo6F Offline
              Which window do you refer to?
                rv1974
                Fredo, 'generate 2d component' tool produced slightly larger 2d representation* of original one (for example 3969mm instead of 3967mm). is there possibility to make it precise?
                *- parallel projection of course, anycontouring mode
                • fredo6F Offline
                  Would you have a model to investigate. I am not sure however that the plugin can do anything about the Sketchup inherent precision.
                    rv1974
                    please take a look
                    Group_23.skp
                      rv1974
                      another issue: some parts in 2D component get lost
                      Group_1.skp
                      • cmeedC Offline
                        cmeed
                        Hi Fredo,
                        I have a few problems using Portrait Studio
                        When its open, SU looks like it jumps back a few steps. if i click into a group with Portrait open it will jump back to what ever happen a few moments ago - if I rotated , altered position or placed an object
                        Please see you personal messages and the dropbox link to the movie i just took
                        Cheers
                        C
                        • fredo6F Offline
                          NEW RELEASE: FredoPortrait v2.8a - 25 Dec 22
                          Requirement:
                          • LibFredo6 13.6a
                          • Sketchucation ExtensionStore v4.2.9
                          FredoPortrait 2.8a is for extension of validity
                          M 1 Reply Last reply Reply Quote 0
                            mbieniu1 @fredo6
                            @fredo6
                            Hello,
                            Is it now possible to batch export files to PDF (in the case of vectors)? I'm looking for an extension for bulk export of PDF files by tags or scenes.
                            • fredo6F Offline
                              NEW RELEASE: FredoPortrait v2.9a - 01 Apr 24
                              Requirement:
                              • LibFredo6 14.3b
                              • Sketchucation ExtensionStore v4.4.0
                              • Sketchup SU2017 and SU2018 for some functions
                              FredoPortrait 2.9a is a maintenance release for:
                              • Future compatibility
                                pierrearchi26
                                This post is deleted!
                                  pierrearchi26
                                  Bonjour Fredo, je voulais savoir si il etait possible d'exporter/creer une scene depuis portrait studio avec uniquement l'objet selectionné et la camera choisie (fonctionnement different de l'outil bloque la camera et la visibilite de l'objet qui est temporaire et ne modifie pas la scene ) ? Pour pouvoir directement utiliser ces scènes dans Layout par la suite ... Gain de temps. Plugin top pour les nomenclatures et les notice de fabrication. Merci.
                                    Dave R @pierrearchi26
                                    @pierrearchi26 said:
                                    So I can then use these scenes directly in Layout... Saves time.
                                    I'm curious how this would save time. Can you explain? Show an example of how you use FredoPortrait for bills of materials and manufacturing instructions. It might help me with some of my work.
                                    Maybe start a thread on this in the Tutorials category.
                                    • fredo6F Offline
                                      FredoPortrait essentially generates images, not scenes. For isolating components and views, it uses temporary settings of the camera and object visibility, but this is transcient.
                                      Generating scenes with isolated objects and specified cameras would be another plugin.
                                      • 4 / 5
