    Worksize in skethup!
    3 Posts 2 Posters 5.4k Views 2 Watching
    • Z
      zborce
      Regards to all!
      • First to apologize for my bad English,
      • I'm going over the bow to translate,
      • I have one specific question:
        How to adjust the arrow to change the shape, when it is brought to the bottom right corner. This is very important for printing in a 1: 1 ratio.
        Thank you in advance for the answer.
      Attachment, pictures ..........................
      no koments
      no koments
        First of all, you don't use the Select tool to change the size of the SketchUp window. Instead, click on the double squares in the upper right hand corner of the SketchUp window. It's between the - and X. then you should be able to grab the edge of corner of the window and drag it to resize it.
        Your profile indicates you are using SketchUp Pro. Instead of trying to print to scale from SketchUp, you should create a scene and then send the file to LayOut. It's much easier to setup and create a scaled view and then export to PDF for printing.
        • Z
          zborce
          OK, that's it,
          • Dave, thanks for the quick and good response.
