    [Plugin][$] FredoGhost - v2.1a - 01 Apr 24
    56 Posts 20 Posters 64.5k Views 20 Watching
    • fredo6F
      fredo6
      The information on FredoGhost is maintained on the Plugin Home Page of FredoGhost. This is also where you can download the RBZ file.
      • LibFredo6: v14.3b or above
      • Sketchucation ExtensionStore: v4.4.0 or above (for licensing)
      • Usage: Licensed under Sketchucation SCFLicense
      • Free Trial period (full features): 15 days from activation
      • Perpetual license (3 seats): $20 (~17€)
      • Rush license (3 seats, valid 21 days from purchase date): $6 (~5€)
      To purchase the license of FredoGhost, go to this page and sign in.
      If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
      Credit: all toolbar icons and button images by JClements
      FredoGhost is a Proxy framework for SketchUp. By ‘proxy framework’, I mean the capability to temporarily replace an object by another one, the proxy, and switch back and forth between the original version and the proxy version.
      In FredoGhost:
      • A Proxy is called a Ghost, and the original object is called a Real.
      • FredoGhost operates on Components and Groups, called generically Objects.
      FredoGhost can be used for 2 main purposes:
      1. Combine different rendering styles in the same view, for instance, some objects in X-Ray, while others staying natural (like in my old plugin XRaySelection). FredoGhost gives you control of the style and of the objects you want to modify.
      2. Make your model lighter to work with, since you can substitute proxies with lighter geometry (including just its bounding box) to replace complex objects. You have some methods to help in that, in particular the 'Proxy' method and the concept of frozen ghosts.
      FredoGhost allows to select the objects you want to ghost and to convert them individually to their Ghost and Real versions. The ghost methods provided can be parameterized at will. It can also associate a particular ghosting state to a Scene, which can be useful both for individual rendering and a faster working environment.
      Most features can be accessed from the FredGhost Studio dialog box, either in basic features or advanced features
      IMPORTANT: For a period, it is advised to make a safe copy of your model, as there might be bugslats or other issues. This will ensure that you keep the main objects of your model in their real form.
      Overview of FredoGhost
      FredoGhost - User Manual - English - v1.2 - 03 Jun 2019 - Overview.pdf
      More details about the Ghost Methods
      FredoGhost - User Manual - English - v1.2 - 03 Jun 2019 - Ghost Methods.pdf
      Just drop the attached PDF file into the SU Plugins directory to have it accessible from within Sketchup.
      0) A quick introduction to FredoGhost main features (no sound)
      Tutorial 1: Basic operations in FredoGhost
      Tutorial 2: Ghost Method Editor
      Tutorial 3: Scene Capture
      Tutorial 4: Layout Compatibility mode
      Tutorial 5: Advanced Features - Working with Components
      Tutorial 6: Advanced Features - Frozen Ghosts
      Tutorial 7: Advanced Features - Sensitivity to Distance
      Tutorial 8: Advanced Features - Ghost Configurations
      Tutorial 9: Under the hood...
      • R
        rv1974
        Amazingly helpful improvements, 1000 thanks!
        • jujuJ
          juju
          looks useful, can't wait, thanks!
          • K
            kenancakir
            Thank you, it will be a must have plugin for presentations..
            • cottyC
              cotty
              Great addition to the superb Fredo collection!
              my SketchUp gallery
              • A
                Ahmed0007
                Thank you Fredo6 ❤
                • fredo6F
                  fredo6
                  NEW RELEASE: FredoGhost v1.2b - 18 Jul 19
                  Requirement: LibFredo6 8.9
                  FredoGhost 1.2b extends validity.
                  Home Page of FredoGhost for information and Download.
                  Main post of this FredoGhost thread.
                  • JQLJ
                    JQL
                    Just came across this Fredo. Amazing stuff!
                    I'm on vacations so will be difficult for me to try it, but one question came to mind: what happens if I convert a component to a ghost and then purge the model. will the original component be purged?
                    www.casca.pt
                    Visit us on facebook!
                    • fredo6F
                      fredo6
                      FredoGhost keeps a copy of the original definition, for Components and Groups, in a safe, hidden place, called the Capsule. So the component definitions will not be purged (and as a result, your components would still be visible in the Component browser).
                      • JQLJ
                        JQL
                        That capsule is a great concept. You always have things covered! I will try this one, as well as portrait, in September, both hold much promise if used right.
                        www.casca.pt
                        • T
                          ttz4
                          Hello Fredo. Is it possible to make "Bounding Box" witch is copying the structure of the original 3D model? I want to see the contours of the model with all the bends and not just the box at the highest points. I attached some metal structure as an example.
                          • fredo6F
                            fredo6
                            Does the method "Bounding box by sub-object" work for you?
                            • T
                              ttz4
                              Not realy. "Bounding box by sub-object" makes objects like in picture №1. But I am wondering, if it possible to make proxy object like in picture №2?
                              №1
                              №2
                              • fredo6F
                                fredo6
                                Not really, as this is an interpretation of the geometry, not a combination of bounding boxes. You would have to construct it yourself and make it a proxy.
                                Anyway, if you can post the model, it would help.
                                Fredo
                                • T
                                  ttz4
                                  Fredo
                                  Here is the model. I exported it from .nwd–>.fbx–>.skp. I have a lot of steel frames that need to be proxied. Now I'm finding the way, how I can do it faster than to rebuild all the frames myself.
                                  Steel_Frame.skp
                                  • fredo6F
                                    fredo6
                                    NEW RELEASE: FredoGhost v1.3a - 19 Oct 19
                                    FredoGhost 1.3a extends validity.
                                    • fredo6F
                                      fredo6
                                      NEW RELEASE: FredoGhost v1.3b - 22 Jan 20
                                      FredoGhost 1.3b extends validity.
                                      • OxerO
                                        Oxer
                                        Spanish Language File
                                        FredoGhost_ES.lang.zip
                                        http://www.oxervision.blogspot.com/
                                        • fredo6F
                                          fredo6
                                          Thank you very much.
                                          Fredo
                                          • fredo6F
                                            fredo6
                                            NEW RELEASE: FredoGhost v1.4a - 21 May 20
                                            Requirements:
                                            • LibFredo6 10.4
                                            FredoGhost 1.4a fixes bugs and extends validity.
                                            • 1 / 3
