    [Plugin][$] FredoGhost - v2.1a - 01 Apr 24
    56 Posts 20 Posters 63.9k Views 20 Watching
    • K
      kenancakir
      Thank you, it will be a must have plugin for presentations..
      • cottyC
        cotty
        Great addition to the superb Fredo collection!
        my SketchUp gallery
          Ahmed0007
          Thank you Fredo6 ❤
          • fredo6F
            NEW RELEASE: FredoGhost v1.2b - 18 Jul 19
            Requirement: LibFredo6 8.9
            FredoGhost 1.2b extends validity.
            Home Page of FredoGhost for information and Download.
            Main post of this FredoGhost thread.
            • JQLJ
              JQL
              Just came across this Fredo. Amazing stuff!
              I'm on vacations so will be difficult for me to try it, but one question came to mind: what happens if I convert a component to a ghost and then purge the model. will the original component be purged?
              www.casca.pt
              Visit us on facebook!
              • fredo6F
                FredoGhost keeps a copy of the original definition, for Components and Groups, in a safe, hidden place, called the Capsule. So the component definitions will not be purged (and as a result, your components would still be visible in the Component browser).
                • JQLJ
                  JQL
                  That capsule is a great concept. You always have things covered! I will try this one, as well as portrait, in September, both hold much promise if used right.
                  www.casca.pt
                  • T
                    ttz4
                    Hello Fredo. Is it possible to make "Bounding Box" witch is copying the structure of the original 3D model? I want to see the contours of the model with all the bends and not just the box at the highest points. I attached some metal structure as an example.
                    • fredo6F
                      Does the method "Bounding box by sub-object" work for you?
                      • T
                        ttz4
                        Not realy. "Bounding box by sub-object" makes objects like in picture №1. But I am wondering, if it possible to make proxy object like in picture №2?
                        №1
                        №2
                        • fredo6F
                          Not really, as this is an interpretation of the geometry, not a combination of bounding boxes. You would have to construct it yourself and make it a proxy.
                          Anyway, if you can post the model, it would help.
                          • T
                            ttz4
                            Here is the model. I exported it from .nwd–>.fbx–>.skp. I have a lot of steel frames that need to be proxied. Now I'm finding the way, how I can do it faster than to rebuild all the frames myself.
                            Steel_Frame.skp
                            • fredo6F
                              NEW RELEASE: FredoGhost v1.3a - 19 Oct 19
                              FredoGhost 1.3a extends validity.
                              • fredo6F
                                NEW RELEASE: FredoGhost v1.3b - 22 Jan 20
                                FredoGhost 1.3b extends validity.
                                • OxerO
                                  Oxer
                                  Spanish Language File
                                  FredoGhost_ES.lang.zip
                                  • fredo6F
                                    Thank you very much.
                                    • fredo6F
                                      NEW RELEASE: FredoGhost v1.4a - 21 May 20
                                      Requirements:
                                      • LibFredo6 10.4
                                      FredoGhost 1.4a fixes bugs and extends validity.
                                      • fredo6F
                                        NEW RELEASE: FredoGhost v1.5a - 19 Aug 20
                                        Requirement: LibFredo6 11.0
                                        FredoGhost 1.5a fixes bugs and extends validity.
                                          rezvan23
                                          Hi Fredo.
                                          Could you add a feature that is like 3ds max's "Display as Box" option, which shows the object as a box in viewport, and shows the actual geometry in render?
                                          I don't mean vrayproxy, that's not editable.
                                          I don't know if that's possible.
                                          Thanks for your great sketchup extensions.
                                          • fredo6F
                                            FredoGhost is not aware of the rendering. So, just before rendering, you need to swap the objects from box to their 'real' version.
                                            • 1 / 3
