    [Plugin][$] FredoGhost - v2.1a - 01 Apr 24
    56 Posts 20 Posters 63.9k Views 20 Watching
    • jujuJ
      juju
      looks useful, can't wait, thanks!
      • K
        kenancakir
        Thank you, it will be a must have plugin for presentations..
        • cottyC
          cotty
          Great addition to the superb Fredo collection!
          my SketchUp gallery
            Ahmed0007
            Thank you Fredo6 ❤
            • fredo6F
              NEW RELEASE: FredoGhost v1.2b - 18 Jul 19
              Requirement: LibFredo6 8.9
              FredoGhost 1.2b extends validity.
              Home Page of FredoGhost for information and Download.
              Main post of this FredoGhost thread.
              • JQLJ
                JQL
                Just came across this Fredo. Amazing stuff!
                I'm on vacations so will be difficult for me to try it, but one question came to mind: what happens if I convert a component to a ghost and then purge the model. will the original component be purged?
                www.casca.pt
                Visit us on facebook!
                • fredo6F
                  FredoGhost keeps a copy of the original definition, for Components and Groups, in a safe, hidden place, called the Capsule. So the component definitions will not be purged (and as a result, your components would still be visible in the Component browser).
                  • JQLJ
                    JQL
                    That capsule is a great concept. You always have things covered! I will try this one, as well as portrait, in September, both hold much promise if used right.
                    www.casca.pt
                    • T
                      ttz4
                      Hello Fredo. Is it possible to make "Bounding Box" witch is copying the structure of the original 3D model? I want to see the contours of the model with all the bends and not just the box at the highest points. I attached some metal structure as an example.
                      • fredo6F
                        Does the method "Bounding box by sub-object" work for you?
                        • T
                          ttz4
                          Not realy. "Bounding box by sub-object" makes objects like in picture №1. But I am wondering, if it possible to make proxy object like in picture №2?
                          №1
                          №2
                          • fredo6F
                            Not really, as this is an interpretation of the geometry, not a combination of bounding boxes. You would have to construct it yourself and make it a proxy.
                            Anyway, if you can post the model, it would help.
                            • T
                              ttz4
                              Here is the model. I exported it from .nwd–>.fbx–>.skp. I have a lot of steel frames that need to be proxied. Now I'm finding the way, how I can do it faster than to rebuild all the frames myself.
                              Steel_Frame.skp
                              • fredo6F
                                NEW RELEASE: FredoGhost v1.3a - 19 Oct 19
                                FredoGhost 1.3a extends validity.
                                • fredo6F
                                  NEW RELEASE: FredoGhost v1.3b - 22 Jan 20
                                  FredoGhost 1.3b extends validity.
                                  • OxerO
                                    Oxer
                                    Spanish Language File
                                    FredoGhost_ES.lang.zip
                                    • fredo6F
                                      Thank you very much.
                                      • fredo6F
                                        NEW RELEASE: FredoGhost v1.4a - 21 May 20
                                        Requirements:
                                        • LibFredo6 10.4
                                        FredoGhost 1.4a fixes bugs and extends validity.
                                        • fredo6F
                                          NEW RELEASE: FredoGhost v1.5a - 19 Aug 20
                                          Requirement: LibFredo6 11.0
                                          FredoGhost 1.5a fixes bugs and extends validity.
                                            rezvan23
                                            Hi Fredo.
                                            Could you add a feature that is like 3ds max's "Display as Box" option, which shows the object as a box in viewport, and shows the actual geometry in render?
                                            I don't mean vrayproxy, that's not editable.
                                            I don't know if that's possible.
                                            Thanks for your great sketchup extensions.
                                            • 1 / 3
