    Layout dimensioning weirdness
    layout
    4 Posts 2 Posters 6.0k Views 2 Watching
      Buckyman
      I am pulling my hair out with this one
      If I dimension the lower edge I get one value, if I dimension the upper edge I get a different value,
      and both of these values is wildly incorrect as you can see from the SU screen shot
      Dimension settings is auto
        It may be the modified scene causing the issue. It's normally not a good idea to modify scenes in LayOut. Can you share the LayOut file so we can see what you've got?
          Buckyman
          Here is the file, thx
          structural_glass_deductions.layout
            Buckyman
            I reset the scene which did not help.
            I did some dimensioning in SU and determined that Layout is reporting the diagonal distance!
