    .skp to .step The easy way!
    3 Posts 3 Posters 1.5k Views 3 Watching
    • Mike LuceyM Offline
      Mike Lucey
      Convert STL to STEP.pdfHi Guys,
      I'm working on a project that entails converting .skp files to .step for online quotes for injection molds and plastic parts.
      I got quite frustrated trying to do the conversions using various online services both free and paid. However, I found a simple solution that works every time and it doesn't cost a penny!
      Just follow the instructions on this PDF which I sourced on ICO Molds.
      Mike
        And so the "Step" will be admissible to Moi3D nurbs modeler! (and so modifiable)! πŸ˜‰ PC & MAC
        Who can be used for free for any penny ; (Alternate version without save) for image (with this little script created by Michael Gibson the creator of Moi - it's not a "Hack"! ) πŸ€“
        (Moi has also the Export SKP if needing in complete version) ! πŸ˜‰
        You can save your screen image in the clip-board at any resolution so image is internal recalculated following your hard memory available! Just copy past it in your favorite 2D prog for edit if needing! πŸ˜‰
        Copy this script "one line" in the second column of the Options/Shortcut or press Tab and copy past it then Press Enter! πŸ˜‰
        You can of course increase/decrease the "2560,2560" just change it! πŸ€“
        script: /* Print Screen on Clip-Board */ var prev_background = moi.view.viewportBackgroundColor; moi.view.viewportBackgroundColor = 0x000000; moi.view.lineWidth = 4; moi.grid.display = false; moi.grid.showXYAxes = false; moi.ui.getActiveViewport().renderToClipboard( 2560, 2560 ); moi.view.lineWidth = 1; moi.grid.display = true; moi.grid.showXYAxes = true; moi.view.viewportBackgroundColor = prev_background;
        Like...(in Black & white here but you can put before of course some colors on your 3D Models! )
        Precision is some cool! (shadows are made in a 2D prog)
        https://i.postimg.cc/4dhCb3YT/test.jpg
          Thanks very much for those, much appreciated.
