    '19 error
    2 Posts 2 Posters 994 Views 2 Watching
      millerjx
      I am running SU '19
      Trying to work.
      I get an error when I open SU. Shut down computer restart same error. Additionally, now I cannot draw dotted lines.
      Any idea what tto do?
      Received this error
      Error Loading File C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2/core.rb
      Error: #<IOError: Staging directory not found>
      C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:101:in prepare_path' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2/core.rb:129:in module:Lib'
      C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2/core.rb:110:in <module:TT>' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2/core.rb:20:in <top (required)>'
      C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load'
      C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2.rb:40:in register_extension' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2.rb:40:in module:Lib'
      C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2.rb:14:in <module:TT>' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_Lib2.rb:13:in <top (required)>'
      Error Loading File C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/tt_cleanup/bootstrap.rb
      C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
      C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/TT_CleanUp/core.rb:10:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
      C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/tt_cleanup/bootstrap.rb:35:in <top (required)>'
      C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/tt_cleanup.rb:42:in register_extension' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/tt_cleanup.rb:42:in module:CleanUp'
      C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/tt_cleanup.rb:15:in <module:Plugins>' C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/tt_cleanup.rb:14:in module:TT'
      C:/Users/John/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/tt_cleanup.rb:13:in `<top (required)>'
        John, I replied to your private message about this. It should get you sorted.
