    SketchUp 2019 CAD file import failure
    8 Posts 5 Posters 2.6k Views 5 Watching
    • IGfortyKI
      IGfortyK
      Hello,
      I am trying to import CAD linework from AutoCAD Architecture 2018 into SketchUp Pro 2019 and the import is failing every time, no matter how simple the linework is.
      I am saving the DWG down (tried each version), I am exploding the linework, and I am removing non-compatible elements (i.e. text, dimensions, etc.).
      When I import into SKP19 I see the dialog box in the attached image (of which I am familiar, but have never had issues with). This example was a simple exploded rectangle (5'x10' drawn on the origin point of a new DWG.
      We recently upgraded to SketchUp 2019 from 2018 earlier this week. Our import method is the same as before and had no issues prior to using SketchUp 2019.
      What could this issue be?
      Thank you!
      Import Result of a simple rectangle drawn on the origin in CAD.
      Windows 10 Pro
      Processor: Intel Core i5-3570 CPU @ 3.40GHz
      RAM: 16 GB
      System Type: 64-bit OS, x64-based processor
        Do you have Preserve Drawing Origin selected in the import options?
        • IGfortyKI
          IGfortyK
          Thanks for the reply.
          Yes, I have tried it selected and not selected. Same result.
          Windows 10 Pro
          RAM: 16 GB
          • J
            JGA
            I had problems with importing DWG into SKUP as well.
            Try the following;-
            • Ensure you're working in World UCS and plan is also set to the World UCS.
            • Save back as plain AutoCAD entities to r14 or r12 DWG format.
            Regards,
            JGA
            • IGfortyKI
              IGfortyK
              Try the following;-
              Thank you for the idea. I just tried that, ensuring I was in World UCS as well as exporting down to R14, but the result was the same. I tried exporting to all versions and none seem to change how it is importing.
              If this issue was just on my workstation I would probably just reinstall SKP19 but my coworker discovered this issue on her PC before I even attempted on mine.
              Windows 10 Pro
              RAM: 16 GB
              • J
                JGA
                Try dumbing down the plain AutoCAD file even more by exploding some blocks to see if they come into SKUP.
                Or
                Get the use of your Trimble Support and put a call in - I was surprised and pleased at how quickly I received a reply from them.
                Regards,
                JGA
                • sketch3d.deS
                  sketch3d.de
                  select all and explode once, save down to the ACAD v2000 format.
                  • regnarR
                    regnar
                    Another Autocad command to try is 'EXPORTTOAUTOCAD' this might remove any hidden proxys
                    Windows 10 Professional 64 bit
                    Intel I9 7900X Asus Prime X299-Delux
                    EVGA GeForce RTX 3080 TI 12gb
                    64 GB Ram Samsung 960 EVO Series 1TB PCIe NVMe M.2
