    Messagebox within a callback fails
    5 Posts 3 Posters 6.9k Views 3 Watching
    • Didier BurD
      Didier Bur
      Hi all,
      I'm encountering this problem:
      When writing a callback function, everything goes well until a messagebox call: the SU window suddenly minimizes to the taskbar 😕 , the message box doesn't pops-up and the callback stops 😲
      Something like this:
      @web_dialog.add_action_callback("wcCreatePlace") { |d, p|
      			# Possible opening ?
      			pushPullDoable=validateFace4Pushpull(face)
      			if pushPullDoable
      				dist=findWallFaceDistance(face)
      				if dist
      # EVERYTHING OK UNTIL HERE
      					rep=UI.messagebox("Open the wall ?",MB_YESNO)
      					face.pushpull(-dist) if rep == IDYES
      Anyone encountered this before ?
      DB
      • fredo6F
        fredo6
        @didier bur said:
        Hi all,
        I don't have the problem, but I use a generic block for the call back and then dispatch the action.
        Anyway, very strange!
        In your code, I see a variable <face> that is not initialized in the block. Is this the real code?
        • Didier BurD
          Didier Bur
          Thanks Fredo,
          No, that's not the real code, simplified for readability.
          En fait, "face" est une variable d'instance @face dans mon vrai code, j'ai simplifié pour poster ici.
          Je n'ai toujours pas solutionné le pb, j'ai mis des mouchards partout pour tracer ce que fait le callback, et dès que la messagebox est appelée, plus rien...
          Je vais calquer ma manière de faire sur la tienne 😉
          DB
          • TIGT
            Change this one line to output 'face' & 'dist' to the Ruby Console just before the failure.
            **p face; p** dist=findWallFaceDistance(face)
            • Didier BurD
              Didier Bur
              @TIG
              Thanks for the hint, unfortunately it doesn't help, I'm getting the correct values for face and dist outputs. BUT, I tried to call message box in others callbacks, it worked in every case.
              So what was wrong with this particular callback ? Guess what, one CANNOT call a UI.messagebox after a webdialog (or html dialog) closes, modal or non-modal.
              There's some kind of logic here...
              This doesn't work:
              # callback cancel
              @web_dialog.add_action_callback("dlg_cancel_settings") { |d, p|
              	@web_dialog.close()
              	r=UI.messagebox("Are you sure ?",MB_YESNO)
              This works:
              # callback cancel
              	@web_dialog.close()
              DB
