    Transparent Background
    layout
    8 Posts 2 Posters 15.4k Views 2 Watching
      suSteve
      is it possible to get a transparent background for a sketchup file inserted into layout
      thank you
        suSteve
        hi
        thank you. Yes that gives a white background. Is a transparent background possible?
        thanks again
        • pbacotP Offline
          @susteve said:
          hi
          thanks again
          Maybe I misunderstood the question.
          • pbacotP Offline
            Yes, use a style with no ground or sky. Don't use fog or a watermark.
              suSteve
              Sorry no you did not misunderstand I think it is my understanding of your answer.
              When I do this I have a white background in layout and any 2D shape stacked behind the skp does not show because of the white. In your example it clearly works so you must have transparency whereas mine is white
              thank you for your time
              • pbacotP Offline
                Doh, corrected post above. It's only necessary to turn off the ground and sky.
                • pbacotP Offline
                  See my second attachment above. Our posts crossed. For some reason, my port settings for Styles was set not to show background, and yours probably was set to show background.
                  So no it isn't possible, but LayOut can be set NOT to show the background. πŸ˜„
                    suSteve
                    Thank you
