    "Isolate" group/component
    11 Posts 3 Posters 2.2k Views 3 Watching
    • N Offline
      numerobis
      In the model settings i can change the way how similar comps and the rest of the model are displayed when i edit a group/comp. To isolate a single comp, both options have to be activated. Is there a plugin that that lets you toggle both options at once with one shortcut?
      • N Offline
        numerobis
        Thank you very much! πŸ˜„
        But i get this at startup...
        • K Offline
          kostiaarh
          Plugin not working. Please fix
          • N Offline
            numerobis
            Ok, i got it working...
            I just copied the structure of some other plugin, so i don't know if this is the correct way to do it. But it's working.
            There is only one problem: it doesn't check the actual display status, so if one of the two hide options is already active, the function will be messed up.
            For me it's working, but i think the more elegant way would be, if it could synchronize both options.
            I tried to place the entry in the existing "Component Edit" submenu, but with "add_submenu" a second entry is generated. Is there a way to add it to the existing submenu?
            hide_all_outside.rb
            • CadFatherC Offline
              CadFather
              sorry, i literally threw it there in passing. i will get a better version done in the next couple of days. as Numerobis says, with some awareness of the current statuses.
              • N Offline
                numerobis
                No problem. Thanks for putting this together! It's already working.
                  CadFather
                  ok, a bit of a fast fix but see if this works better
                  hide_all_outside.rb
                    CadFather
                    on windows you can use this - put is as a menu under 'View' so you can assign a shortcut.
                    • N Offline
                      numerobis
                      Yes, it works! Very cool. Thanks!
                      Is it possible to add it to the "Component Edit" submenu?
                        CadFather
                        unfortunately not, sketchup just adds a duplicate submenu. however if you open the script, you can move it from 'view' to anything you prefer.
                        • N Offline
                          numerobis
                          Yes, i noticed that as well. Anyway... it just would have been a bit more clean and organized. But that's really a minor thing.
                          Thanks again for your help! πŸ˜„
