    LO back up
    layout
    5 Posts 2 Posters 6.1k Views 2 Watching
    • M
      millerjx
      I have LO back up set to every 5 minutes. I just lost 2 hours of work. How do I get autosave to save consistently, and often?
        Are you saving the file on a local drive? Did you look at the backup copy of the LO file?
        • M
          millerjx
          No
          I use drop box for my file management. Does that interfere? I never even considered the possibility
            It can if you are saving directly to Drop Box. Doing that is not recommended. The link to the cloud is too tenuous to count on and due to the typical longer write time, auto saves frequently fail. Best practice is to save your files locally and then sync to Drop Box if you need them to be there.
            • M
              millerjx
              Thanks Dave
              Any luck inserting the autocad drawing from yesterday?
