    RELOADING COMPONENTS / UPDATING NESTED COMPONENTS
    1 Posts 1 Posters 1.5k Views 1 Watching
    • G
      greenb152
      Hi There,
      I am struggling with this.
      I have a saved component (A.skp) that contains a series of nested components (B + C + D) in SKP Model01.
      I edit component (B) inside component (A) and then re-save component (A.skp) and open a different SKP file: SKPModel02 that also contains component (A). This new file also contains other instances of component (B) which are not nested within component (A).
      When I reload the updated component (A.skp) to the new SKP file it updates component (A) as it should but component (B) becomes component (B#1) and I am left with non-updated instances of component (B) in the model.
      I guess I could save out component (B) as a file - but as a process this would include thousands of files fo every individual component all needing to be manually updated.
      So basically, how can I reload an updated component (A) in a way that it will recognise that nested components (B) have been updated and update all instances of component (B) in the relevant model?
      I think that's as simple as I can put it?
      many thanks
      Ben
