    Importing autocad
    layout
    4 Posts 2 Posters 6.1k Views 2 Watching
    • M
      millerjx
      I continue to struggle to bring autocad into Layout. I back save to Autocad 2010. (Is that the right version, or does earlier work better?) I am running SU 2018. Sometimes it works sometimes not. Is there a tutorial to get it to work consistently?
      Also, can I bring text in from Autocad?
      My workaround is to print as pdf, convert to jpg image bring it in, try to scale it close. Seems like there has to be a better way
      Thanks for the help!!
      John
        What settings are you using in LO when you import the CAD file?
        Have you gone through the info on this page?
        https://help.sketchup.com/en/layout/importing-cad-data-layout
        • M
          millerjx
          Dave
          Yes, I have used that page, and video by Brightman.
          I have tried to insert paperspace with and without SU model reference checked.
          The document I am inserting has text. Text does not come. 4 out of 5 tries I get an error, says "The following file failed to insert, naming the cad file path"
            Hmmmm...
            Could you share the CAD file? Send it by PM if you don't want to make it public.
