    Jim's Custom Toolbar plugin not working in 2019
    5 Posts 3 Posters 1.1k Views 3 Watching
    • kenK
      ken
      Jim's custom toolbar is not working in 2019. I know that Jim has moved his plugins and may not want to update this plugin.
      So is there another way to make custom Sketchup toolbars besides Jim's plugin. Really like making custom toolbars.
      Thanks in advance
      Ken
      • jujuJ
        juju
        Toolbar Editor
        I used it a few years ago, worked pretty well then, but wouldn't work in later SU versions. It has been updated since. Compatibility is shown to be across SU8 to SU2018, not sure if it will work in SU2019 but should.
        Although I had a problem with it in SU2018 and had tried to contact the author (and / or get his attention) without much success. Let's just call it a flat ignore, from my perspective anyhow, but then again it is free, so no expectations or any commitments then, eh.
        • kenK
          ken
          Trail and error. Fixed
          • TIGT
            A clue on your 'fix' would be helpful to other members, who might have this problem or similar issues...
            • kenK
              ken
              I will do that TIG. I didn't do it after I made the correction, because the plugin wasn't mine and Jim over the years has made me a couple of life-saving plugins.
              I am not a code writer. I am sure others will find this not the optional solution, however, it does work for me. I would like to see this plugin modified so it is correct for 2019 and future versions of Sketchup but don't wish to step on anyone's toes.
              See the attached PDF document to see how I modified the directory "Toolbars" to make the plugin work.
              The short answer is I moved the plugin "Loader.rb" from the directory "Files" to the directory "Toolbars"
              The structure of the 2018 toolbar directory.pdf
