    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    Blender forum in sketchucation
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    48 Posts 21 Posters 34.3k Views 21 Watching
    • andybotA Offline
      andybot
      @ntxdave said:
      So what is the best way to move my models to Blender 2.8?
      I tried .dae and only parts showed up. I also tried fbx but got a message in Blener 2.8 that it did not support fbx.
      I've been consistently using .obj export for years with good results. I find duplicate faces and lots of other problems with .dae
      You can use AutoDesk's FBX converter to convert to a different FBX format that will import correctly. I forget the details as I use it infrequently, but it is possible.
      • soloS Offline
        solo
        @andybot said:
        Do we have a subforum yet!? πŸ˜„ I want to discuss pros and cons of obj vs. dae format import. Nice intro video you linked Solo, glad to see they are finally taking seriously the UI compatibility with other software
        We are still waiting for Rich O'Brien to create the subforum, I do not have admin rights to do it.
        http://www.solos-art.com
        • andybotA Offline
          andybot
          Sounds like some more changes coming to Sketchucation than just an additional subforum πŸ˜„
          http://sketchucation.com/forums/viewtopic.php?p=646088#p646088
          @rich o brien said:
          OK, we'll get you guys a Blender forum for SketchUp users up and running.
          We are doing some server upgrades at the moment as we need to move to a newer php version. So give us a day or 2 to get something set up.
          • F Offline
            fossa
            Looking forward to the new Blender sub-forum. The 2.8 UI overhaul is unbelievable. Kudos all around for the blender devs that worked on that. Can't wait for more Blender topics....
            In response to some threads above about DAE vs OBJ. I've been having good luck with DAE imports from SU. It places all objects in an "empty" and scales the empty to the correct units. Haven't had any problems with duplicate faces.
            Now I'm just trying to figure out how to deal with "empty" object types in Blender. πŸ˜„
            • pbacotP Offline
              I've also used the Blender skp importer add-on, but it only works up to 2.79 and then you can open in 2.8.
              • K Offline
                Khai
                Thinking, while we're waiting, could we make clearly labeled threads (think "blenducation : having issues importing....") to go on with, with the labels making it easy to round em up and move them when the forums active?
                • chippwaltersC Offline
                  chippwalters
                  @rv1974 said:
                  @chipp, are they planning to add skp to supported import formats?
                  Haven't heard anything about that. I sorta doubt it. Of course someone could always write a plugin, but going from SU to Blender isn't that hard using .OBJ (IMO).
                  Currently working with Cross-Reality technologies
                    chippwalters
                    I guess this never happened. 😞
                    • 3 / 3
