    Match Photo and Moving Origin
    2 Posts 2 Posters 1.7k Views 2 Watching
    • L
      lxln
      With the match photo tool when is it you can
      • move the origin independent of the model and when does the
      • model move with the origin ?
      I'm sure its simple but its driving me mad !
      I have a drawn model I'm trying to adjust into a photo...
        If you are in the setup mode for Match Photo, moving the origin is really more like moving the image relative to SketchUp's fixed origin. You would set the axes so that the origin aligns with some easily identifiable corner in the image.
        You might find it easier to set up the Match Photo image in a separate file and then copy the model into that file to place it where you need it.
        If you share the SKP file of your model and the image you are using, I can give you more specifics.
