    Light issue
    renderpluginsextensions
    2 Posts 2 Posters 3.1k Views 2 Watching
    • M
      mixzzz007
      Hi, so the issue is when rendering some intensive light such as rectangle light (like in example) it renders in these pixels, not smooth line, same with other subject emissive light and etc.
      My question is which settings should I increase to get clean smooth line light?
      • Robby_GFR
        Robby_GF
        The first thing I would check is your Antialiasing settings - if they are high enough to smooth those jagged edges and try different filters.
        If that doesn't help it might be some issue with color clamping - I would try to turn on/off "Subpixel clamp" option and play with it's value. Also color clamping in Frame Buffer can sometimes give such an effect.
        Robby
        GarageFarm.NET The Cheapest Render Farm - 20,000 cores and growing!
