🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Trouble with commit operation
10 Posts 2 Posters 6.7k Views 2 Watching
  • V Offline
    vico44
    I try to do a new plugin to save open and reload component inside a model and creat xref directory, it works well.
    But i got trouble when I try to add "Model.start_operation" the plugin no longer works (refuse to load the new component). Any idea?
    The attach file is functional for the trouble one you can erase the "#" on line 62 and line 83.
    Vico_newfile.rb
    • F Offline
      fredo6
      Just put model.commit_operation before model.save.
      model.commit_operation is used to commit the geometry, and it must be done before you save the file, which is a separate operation.
      • V Offline
        vico44
        Thanks for the answers, but still not working... 😞
        • F Offline
          fredo6
          Then, it is something else, and you should track the progress of the reload() method with some putsstatement to see what is going wrong.
          • V Offline
            vico44
            when i use the "model start opération" the line -> new_definition = model.definitions.load(path) doesn't work at all and new_definition goes to the same definition of the old_definition.
            but the reload() method works good if i don't use "model start opération" i got a new_definition and can remove the old one.
            really strange.
            On peut parler français remarque non?
            • F Offline
              fredo6
              really strange.
              Donc il faut peut-être mettre la ligne new_definition = model.definitions.load(path) en dehors du block [ start_operation, commit_operation]
              • V Offline
                vico44
                Au bah oui pourquoi j'n y es pas penser 😉
                • V Offline
                  vico44
                  Bon c'est pas le top, mais ça marche:
                  J'ai placer la ligne problématique (ligne 72) entre deux start_operation.
                  Vico_newfile.rb
                  • F Offline
                    fredo6
                    Tu pourrais faire une seule operation [start, commit] pour le guide point et le remplacement.
                    A few remarks:
                    1. You need to be careful when you perform a loop on an object, and the process in the body can alter this object. In your case, old_definition.instances is altered when you change the definition of its instances.
                    old_definition.instances.each { |i| i.definition = new_definition }
                    so you may want to use instead a copy of the list of instances
                    old_definition.instances.to_a.each { |i| i.definition = new_definition }
                    1. You can reorganize the code for more clarity (use also a consistent Tabbing)
                        def self.reload
                    		model = Sketchup.active_model
                    		select_composant = Sketchup.active_model.selection[0]
                    		old_definition = select_composant.definition
                    		good_name = old_definition.name
                    		filename = good_name + ".skp"
                    		path = old_definition.path
                    		#Path does not exist
                    		unless File.exist?(path)
                    			UI.messagebox("Error; Could not find file;\n\"#{path}\"" )
                    			return
                    		#Load new_definition
                    		unless new_definition
                    			UI.messagebox("Error; Could not load component; \"#{File.basename(filename,".*")}\"")
                    			return
                    		#Add guide point at origin
                    		model.start_operation("préparation", true)
                    		select_composant.locked = false
                    		entities = old_definition.entities
                    		entities.add_cpoint(ORIGIN)
                    		#Replace definition
                    		model.start_operation("remplacer", true)
                    		new_definition.name = good_name
                    		model.definitions.remove(old_definition.name)
                    	end # reload
                    • V Offline
                      vico44
                      En fait le guide point sert à modifier l'ancien composant a cause d'un bug sur model.definitions.load(path) qui refuse de lire un composant dans le même répertoire qu'un composant enregistrer si celui ci n'est pas modifier.
                      Je suis donc obliger de mettre la partie guide point avant model.définitions.load(path).
                      cf : https://sketchucation.com/forums/viewtopic.php?f=180&t=60568
