    Trouble with commit operation
    10 Posts 2 Posters 7.0k Views 2 Watching
    • V Offline
      vico44
      I try to do a new plugin to save open and reload component inside a model and creat xref directory, it works well.
      But i got trouble when I try to add "Model.start_operation" the plugin no longer works (refuse to load the new component). Any idea?
      The attach file is functional for the trouble one you can erase the "#" on line 62 and line 83.
      Vico_newfile.rb
      • fredo6F Offline
        Just put model.commit_operation before model.save.
        model.commit_operation is used to commit the geometry, and it must be done before you save the file, which is a separate operation.
        • V Offline
          vico44
          Thanks for the answers, but still not working... 😞
          • fredo6F Offline
            Then, it is something else, and you should track the progress of the reload() method with some putsstatement to see what is going wrong.
            • V Offline
              vico44
              when i use the "model start opération" the line -> new_definition = model.definitions.load(path) doesn't work at all and new_definition goes to the same definition of the old_definition.
              but the reload() method works good if i don't use "model start opération" i got a new_definition and can remove the old one.
              really strange.
              On peut parler français remarque non?
              • fredo6F Offline
                really strange.
                Donc il faut peut-être mettre la ligne new_definition = model.definitions.load(path) en dehors du block [ start_operation, commit_operation]
                • V Offline
                  vico44
                  Au bah oui pourquoi j'n y es pas penser 😉
                  • V Offline
                    vico44
                    Bon c'est pas le top, mais ça marche:
                    J'ai placer la ligne problématique (ligne 72) entre deux start_operation.
                    Vico_newfile.rb
                    • fredo6F Offline
                      Tu pourrais faire une seule operation [start, commit] pour le guide point et le remplacement.
                      A few remarks:
                      1. You need to be careful when you perform a loop on an object, and the process in the body can alter this object. In your case, old_definition.instances is altered when you change the definition of its instances.
                      old_definition.instances.each { |i| i.definition = new_definition }
                      so you may want to use instead a copy of the list of instances
                      old_definition.instances.to_a.each { |i| i.definition = new_definition }
                      1. You can reorganize the code for more clarity (use also a consistent Tabbing)
                          def self.reload
                      		model = Sketchup.active_model
                      		select_composant = Sketchup.active_model.selection[0]
                      		old_definition = select_composant.definition
                      		good_name = old_definition.name
                      		filename = good_name + ".skp"
                      		path = old_definition.path
                      		#Path does not exist
                      		unless File.exist?(path)
                      			UI.messagebox("Error; Could not find file;\n\"#{path}\"" )
                      			return
                      		#Load new_definition
                      		unless new_definition
                      			UI.messagebox("Error; Could not load component; \"#{File.basename(filename,".*")}\"")
                      			return
                      		#Add guide point at origin
                      		model.start_operation("préparation", true)
                      		select_composant.locked = false
                      		entities = old_definition.entities
                      		entities.add_cpoint(ORIGIN)
                      		#Replace definition
                      		model.start_operation("remplacer", true)
                      		new_definition.name = good_name
                      		model.definitions.remove(old_definition.name)
                      	end # reload
                      • V Offline
                        vico44
                        En fait le guide point sert à modifier l'ancien composant a cause d'un bug sur model.definitions.load(path) qui refuse de lire un composant dans le même répertoire qu'un composant enregistrer si celui ci n'est pas modifier.
                        Je suis donc obliger de mettre la partie guide point avant model.définitions.load(path).
                        cf : https://sketchucation.com/forums/viewtopic.php?f=180&t=60568
