    Trouble with commit operation
    10 Posts 2 Posters 7.0k Views 2 Watching
    • V Offline
      vico44
      I try to do a new plugin to save open and reload component inside a model and creat xref directory, it works well.
      But i got trouble when I try to add "Model.start_operation" the plugin no longer works (refuse to load the new component). Any idea?
      The attach file is functional for the trouble one you can erase the "#" on line 62 and line 83.
      Vico_newfile.rb
      • fredo6F Offline
        Just put model.commit_operation before model.save.
        model.commit_operation is used to commit the geometry, and it must be done before you save the file, which is a separate operation.
        • V Offline
          vico44
          Thanks for the answers, but still not working... 😞
          • fredo6F Offline
            Then, it is something else, and you should track the progress of the reload() method with some putsstatement to see what is going wrong.
            • V Offline
              vico44
              when i use the "model start opération" the line -> new_definition = model.definitions.load(path) doesn't work at all and new_definition goes to the same definition of the old_definition.
              but the reload() method works good if i don't use "model start opération" i got a new_definition and can remove the old one.
              really strange.
              On peut parler français remarque non?
              • fredo6F Offline
                really strange.
                Donc il faut peut-ĂȘtre mettre la ligne new_definition = model.definitions.load(path) en dehors du block [ start_operation, commit_operation]
                • V Offline
                  vico44
                  Au bah oui pourquoi j'n y es pas penser 😉
                  • V Offline
                    vico44
                    Bon c'est pas le top, mais ça marche:
                    J'ai placer la ligne problématique (ligne 72) entre deux start_operation.
                    Vico_newfile.rb
                    • fredo6F Offline
                      Tu pourrais faire une seule operation [start, commit] pour le guide point et le remplacement.
                      A few remarks:
                      1. You need to be careful when you perform a loop on an object, and the process in the body can alter this object. In your case, old_definition.instances is altered when you change the definition of its instances.
                      old_definition.instances.each { |i| i.definition = new_definition }
                      so you may want to use instead a copy of the list of instances
                      old_definition.instances.to_a.each { |i| i.definition = new_definition }
                      1. You can reorganize the code for more clarity (use also a consistent Tabbing)
                          def self.reload
                      		model = Sketchup.active_model
                      		select_composant = Sketchup.active_model.selection[0]
                      		old_definition = select_composant.definition
                      		good_name = old_definition.name
                      		filename = good_name + ".skp"
                      		path = old_definition.path
                      		#Path does not exist
                      		unless File.exist?(path)
                      			UI.messagebox("Error; Could not find file;\n\"#{path}\"" )
                      			return
                      		#Load new_definition
                      		unless new_definition
                      			UI.messagebox("Error; Could not load component; \"#{File.basename(filename,".*")}\"")
                      			return
                      		#Add guide point at origin
                      		model.start_operation("préparation", true)
                      		select_composant.locked = false
                      		entities = old_definition.entities
                      		entities.add_cpoint(ORIGIN)
                      		#Replace definition
                      		model.start_operation("remplacer", true)
                      		new_definition.name = good_name
                      		model.definitions.remove(old_definition.name)
                      	end # reload
                      • V Offline
                        vico44
                        En fait le guide point sert Ă  modifier l'ancien composant a cause d'un bug sur model.definitions.load(path) qui refuse de lire un composant dans le mĂȘme rĂ©pertoire qu'un composant enregistrer si celui ci n'est pas modifier.
                        Je suis donc obliger de mettre la partie guide point avant model.définitions.load(path).
                        cf : https://sketchucation.com/forums/viewtopic.php?f=180&t=60568
