    Un reliable update messages?
    2 Posts 2 Posters 844 Views 2 Watching
    • C
      CalypsoArt
      I get update messages from 3 sources. Sketchucation Extension Store, Fredo6 update check, and the Trimble extension warehouse. When I get from the Extension store, the update process goes well and it says all updated. However, a run of Fredo6 plugin check shows updates available. Most I know have been updated. Further, update notifications from Trimble's extension warehouse are sometime problematic and I'd like to disable them. Suggestions?
      • fredo6F
        fredo6
        Do you have an example?
        1. Sketchucation ExtensionStore is the trustable source, because this is where I publish the plugins.
        2. LibFredo6 Check For Update can be slightly off-sync (intentionally), because I usually wait for a few downloads of a new version to turn it on. However, it should not say that there is anything to update if ExtensionStore tells you have everything up to date.
          Note that you can still get the dialog box showing periodically even if everything is up to date. LibFredo6 never does a check online in the background unless you press the button "Check For Update". SO the display of the dialog box is only dependent on the last time you did a check.
        3. For my plugins, forget Trimble Extension Warehouse, as I don't publish there and just expose a link to Sketchucation. But for other authors, this can be the trustable source.
