    VRay Light/Shadow Issue
    renderpluginsextensions
    2 Posts 1 Posters 2.8k Views 1 Watching
    • IGfortyKI
      IGfortyK
      Hello,
      SketchUp user and VRay amateur. I am simply trying to render this perspective. The issue is apparent, i think. The faces facing the sun are rendering with odd shading around my "cut opening" components (the windows and the panel joints). I have tried both the CPU and GPU engine, draft and low quality settings, and have not changed any other default sun settings. Also, I do not have any hidden geometry where it occurs.
      How do I get rid of those triangular patches of shadow/light so it renders as a singular plane?
      Thank you!
      VRay render
      SketchUp screenshot
      Windows 10 Pro
      Processor: Intel Core i5-3570 CPU @ 3.40GHz
      RAM: 16 GB
      System Type: 64-bit OS, x64-based processor
      • IGfortyKI
        IGfortyK
        For those curious, I re-rendered it on a PC with a better CPU and GPU and it came out fine, no issues. But I am still curious as to why this problem occurs in the first place, perhaps I can improve my modeling/rendering methods to avoid it.
        Windows 10 Pro
        RAM: 16 GB
