    Mod Swag
    9 Posts 6 Posters 1.6k Views 6 Watching
    • tuna1957T Offline
      tuna1957
      More Box inspired stuff..... does this mean I've been "Boxified". Drew the little bit down in front. Copied around in a circle. Grouped the ring and copied it up to make the shade. Flipped the top ring on blue axis. Exploded and made the shade a component. Ran Solid Inspector to get rid of internal faces. Gave it SubD and there you go ! Added the metal bits and glass globe and we have a retro swag lamp. Stuck it in a little scene to render. Think it's kinda cool...
      • Mike AmosM Online
        Very nice piece, well done.
        • BoxB Offline
          A great example of how to use multiple instances of one component to build a complex structure with little cleanup needed.
          • tuna1957T Offline
            tuna1957
            Thanks Mike, Box thank you for your great gif's. Learn a lot of new things and how to model more efficiently from
            them !
            • pbacotP Offline
              Great lamp example and render. Is the outer cage of the lamp supposed to be transparent plastic? Nice effect on the wall.
              • tuna1957T Offline
                tuna1957
                Thanks pbacot and your right I set up the material on the outer cage to have some translucence in the render .
                • Bryan KB Offline
                  Cool as always!
                  • david_hD Offline
                    david_h
                    very cool and classic.
                    Looks like I'll have to Watch "Creature from the Black Lagoon" again>
                    • tuna1957T Offline
                      tuna1957
                      Bryan, david h, thanks gents.
