Mod Swag
More Box inspired stuff..... does this mean I've been "Boxified". Drew the little bit down in front. Copied around in a circle. Grouped the ring and copied it up to make the shade. Flipped the top ring on blue axis. Exploded and made the shade a component. Ran Solid Inspector to get rid of internal faces. Gave it SubD and there you go ! Added the metal bits and glass globe and we have a retro swag lamp. Stuck it in a little scene to render. Think it's kinda cool...
Very nice piece, well done.
A great example of how to use multiple instances of one component to build a complex structure with little cleanup needed.
Thanks Mike, Box thank you for your great gif's. Learn a lot of new things and how to model more efficiently from
them ! -
Great lamp example and render. Is the outer cage of the lamp supposed to be transparent plastic? Nice effect on the wall.
Thanks pbacot and your right I set up the material on the outer cage to have some translucence in the render .
Cool as always!
very cool and classic.
Looks like I'll have to Watch "Creature from the Black Lagoon" again>
Bryan, david h, thanks gents.
