    SkethUcation privacy https
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    48 Posts 12 Posters 36.9k Views 12 Watching
    • jujuJ Offline
      juju
      This morning, when checking in at sketchUcation, I get a privacy error problem, yesterday evening it was still fine. I have not done any updates to my browser (but it may have updated silently in the background).
      I was pretty sure that sketchUcation was previously sorted in terms of https vs regular http or www - did anything change in the last 12 hours?
      • F Offline
        faust07
        The same here with edge (Windows 10 Pro) - but with IE (Windows 7 Pro) not..
        • sketch3d.deS Offline
          sketch3d.de
          the used COMODO certificate is expired (21. November 2018, 23:59:59 GMT), clicking on the lock symbol (or something similar) in the browser address bar should reveal according infos.
            rv1974
            Today I've got a constant 'Your clock is ahead' error on android phone
              Same for me "Certicat invalide"! ...Continue anyway...on each page so some painful!
              Smiley affected!
              • TIGT Online
                Refresh your browsers...
                Should be OK now.
                Rich/Gábor changed the Certificate system - which broke !
                But I think it's now all pukka...
                  Works fine now! 👍
                  • sfto1S Offline
                    sfto1
                    works fine here too!
                    • K Offline
                      kaas
                      ditto again with Bitdefender
                      • jujuJ Offline
                        juju
                        Thanks to all involved, working fine again now!
                          The problem has returned! ❗ ❗ ❗
                          • jujuJ Offline
                            juju
                            And seems to be have been solved again as well ❗ ❗ ❗
                            (I'm not seeing the problem now, thus the assumption.)
                            • soloS Offline
                              solo
                              SCF only works with http and not https now.
                              http://www.solos-art.com
                              • BoxB Offline
                                No Solo, you need to refresh your browser if that is the case.
                                Unless of course different servers have different results.
                                • jujuJ Offline
                                  juju
                                  https here
                                  • TIGT Online
                                    It still works fine for me with https [if I try http, then my browser uses https anyway !]
                                    Maybe Rich/Gábor have been tweaking the certification again !
                                    • soloS Offline
                                      solo
                                      • TIGT Online
                                        Solo
                                        Have you cleared your browser's cache ?
                                        • soloS Offline
                                          solo
                                          @tig said:
                                          Solo
                                          Yes, just did and still get same results.
                                          • TIGT Online
                                            I assume you are on Chrome ?
                                            • 2 / 3
