    SkethUcation privacy https
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    48 Posts 12 Posters 36.9k Views 12 Watching
      Pherim
      I still have this problem with Firefox and Chrome.
        Gábor
        @pilou said:
        Alas always certificated and not securised after cache killing! 😮
        Sorry, I do not understand exactly the phenomenon. If you click the lock icon at the URL line of your browser is it indicating that the certificate is secure? Do you see the certificate details? Could you please send me what you see there?
        (For me it is fine with all the browsers I have so I do not see any problems with the site with my browsers.)
          Gábor
          Could you please send me a screenshot about what you see? Also could you please click on the lock icon in your browser's URL line and see the certificate details there?
            Pherim
            The problem is, it's in German, I don't know if it would be of any use to you. I installed a portable English Firefox version to give you an English error screen, but the page works with that one for some reason. Then I tried creating a new profile, and once again it didn't work.
            But now I switched back to my main profile and it appears to be working. Let's hope it stays like this. 👍
            It still doesn't work in Chrome, but I only used this to check if Firefox was the problem. There i get the following error:
            NET;;ERR_CERT_REVOKED
            Subject; *.sketchucation.com
            Issuer; COMODO RSA Domain Validation Secure Server CA
            Expires on; 23.11.2019
            Current date; 26.11.2018
            And then a huge amount of apparently random characters and numbers.
            Edit: Now the problem is back. The forums work without "https://" in front of "sketchucation.com", but when I click the icon in the address bar (there is only a shield, not a lock on this page), it says that the connection isn't secure.
              I'll cleared all caches and restarted - with limited success.
              Both Firefox [which says Verified by Comodo CA Limited] and Chrome [similar Comodo RSA msg - valid for one year to 22 Nov 2019] do not have this certificate error.
              But Edge and IE11 still balk at 'server certificate revoked/expired'...
              Is this perhaps a virus-checker db out of date ?
                Gábor
                Thank you. I've contacted our certificate issuer and it seems they made a mistake revoking the certificate. They sent me an other certificate what I've installed now. Could you please check now again with cache erase reload? If the problem seems to be fixed, please also check the expiry date of the cert.
                FYI: The online SSL checker shows that everything is ok with the cert now: https://www.sslshopper.com/ssl-checker.html#hostname=sketchucation.com
                  Pherim
                  No change so far...
                    Gábor
                    @pherim said:
                    No change so far...
                    Thank you. If you click the https://www.sslshopper.com/ssl-checker.html#hostname=sketchucation.com link, does it show for you as well that the cert is OK?
                      The SSL shopper link shows it's valid.
                      BUT, even with a cleared cache etc, both Edge and IE11 [AND Avast WebShield] report that SCF is using a revoked certificate, and block it !
                      As before, Firefox and Chrome are both OK, and report the SCF certificate as valid !
                        Gábor
                        Thank you for the information. FYI: I've contacted again our certificate issuer and now they are looking deeper into it. Will let you know when I get any information from them.
                          Pherim
                          Now it works properly with https:// and I get the green lock icon!
                          • soloS Offline
                            still not working for me on Chrome or edge
                              Pherim
                              Yes, Chrome also still doesn't work for me.
                              • jujuJ Offline
                                juju
                                https still fine here
                                  Gábor
                                  Thank you everybody for the feedback.
                                  Now it should be ok for everybody as our cert issuer solved the problem. It was a problem on their side, they accidentally revoked the cert. The solution was that they gave us a new one.
                                  I just hope it won't happen again with the new one.
                                    Pherim
                                    Chrome works now.
                                      I confirm that the latest SCF certificate now works OK for me in the following browsers:
                                      • Firefox
                                      • Chrome
                                      • Edge
                                      • IE11 😄
                                      • soloS Offline
                                        Fixed now
                                          Re works fine now! 👍 (Opera)
                                          Till the next time! 😉
                                            Gábor
                                            Thank you very much everybody for checking it.
                                            • 2 / 3
